Rebar Cover Geometry Extraction/ Visualizing- using C#
tinuthomasGE9RJ
tinuthomasGE9RJ
Hi Team,
 Do We have any way's to Extract/ Visualize the rebar cover geometry given to the host element. I need to create curves with respect to the cover geometry
could anyone can help me on this topic.
jeremy_tammik
ChatGPT now supports improved real-time access to the Internet:
Therefore, It can now be used to answer questions that require it to look for answers in the Revit API discussion forum, The Building Coder blog, and elsewhere on the web.  Therefore, I simply rephrased your question as follows and received the attached answer. Please check it out and see whether it helps you move forward. Please let us know the results and how you and up solving this. Thank you!
Question:
How can I use the Revit API to Extract and Visualize the rebar cover geometry given the host element? I need to create curves with respect to the cover geometry. This has been discussed in the Revit API discussion forum and by The Building Coder blog.
Answer by ChatGPT:
To extract and visualize rebar cover geometry using the Revit API, you can follow these steps:
  1. Access the Host Element: Start by getting a reference to the host element (e.g., a concrete beam or column) that has the rebar cover. This will allow you to access its geometry.
  2. Retrieve Rebar Cover: The Rebar Cover in Revit is associated with the host element. You can use the RebarCoverType and Element properties to find the cover geometry. Use the Parameter named "Rebar Cover - Top Face," "Rebar Cover - Bottom Face," etc., depending on which faces you are interested in.
  3. Get Geometry: Use the Options class to define your geometry extraction preferences (e.g., setting IncludeNonVisibleObjects if necessary). Then, use element.get_Geometry(options) to extract the geometry of the host element.
  4. Filter Cover Faces: Once you have the geometry, filter for faces. You may use a combination of Face classes and methods to isolate the specific faces where the rebar cover is applied.
  5. Determine Offset for Cover Geometry: Revit API does not provide a direct method to create cover geometry as objects. You can programmatically create cover lines or planes by offsetting the faces you extracted. Use the Face.ComputeOffset method if applicable, or manually offset by the cover distance specified by RebarCoverType.CoverDistance.
  6. Create Curves: Using the cover distance and geometry faces, create curves. The Curve class in the Revit API can be used to create lines or arcs representing the boundaries of the cover.
  7. Visualization: To visualize these curves in Revit, add them as model lines or use temporary graphics. You can use Document.Create.NewModelCurve for permanent lines, or TemporaryGraphicsManager to show temporary lines.
Example Code
Here is a simplified code outline in C# to extract cover geometry and create curves around it:
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
    Document doc = commandData.Application.ActiveUIDocument.Document;
    // Assume you already have the host element (like a structural element)
    Element hostElement = ... // retrieve your host element here
    // Get geometry options
    Options geomOptions = new Options();
    GeometryElement geomElement = hostElement.get_Geometry(geomOptions);
    double coverDistance = GetCoverDistance(hostElement); // retrieve cover distance from rebar cover type
    // Iterate through geometry to find the faces
    foreach (GeometryObject geomObj in geomElement)
        Solid solid = geomObj as Solid;
        if (solid != null)
            foreach (Face face in solid.Faces)
                // Compute offset face or create curves around the face based on coverDistance
                List<Curve> coverCurves = CreateCoverCurves(face, coverDistance, doc);
                // Display curves in model (e.g., as model lines)
                using (Transaction tx = new Transaction(doc, "Create Rebar Cover Curves"))
                    tx.Start();
                    foreach (Curve curve in coverCurves)
                        doc.Create.NewModelCurve(curve, sketchPlane);
                    tx.Commit();
    return Result.Succeeded;
// Helper methods to retrieve cover distance and create curves around face would go here
Additional References
  • Look at The Building Coder blog by Jeremy Tammik. He often discusses geometry extraction, cover, and curve generation in Revit API.
  • The Revit API Forum also has discussions around extracting cover and rebar geometry.
This approach provides a general workflow and can be tailored based on the specific cover types and face orientations in your project.
tinuthomasGE9RJ
Thanks @jeremy_tammik ,
I extracted the host geometry, using each face and the known Curve Distance I'm able to extract the geometry. I Faced issue while finding the curves of Cover from the face edgeLoops (x and y axis will return error). In that case first I used the edge curve to make an offset in z direction, and made the offset curve translation in z direction (to eliminate x&Y axis error).
below is the code i used to find the curve of an edgeLoop curve;
Curve hostFaceCurveOffset= curve.CreateOffset(coverDist, XYZ.BasisZ); //to move horizontally
Curve hostFaceCurveTranslation= offset.CreateTransformed(Transform.CreateTranslation(new XYZ(0, 0, coverDist))); // To move vertically
jeremy_tammik
Thank you. So, was the AI-generated answer useful for solving the issue? That is great news.
jeremy_tammik
Shared this thread on the blog as the First LLM Forum Solution:
