Issue Loading Add-In in Revit 2025.3 VSC-22 PART.2
Storm_Clayton
Storm_Clayton
Hi Jeremy,
I hope you're doing well. I wanted to check if you could assist me again with the issue you mentioned regarding the title: "Issue Loading Add-In in Revit 2025.3 VSC-22."
I really appreciate your help and guidance. Looking forward to your response!
Best regards,
moturi.magati.george
Hi @Storm_Clayton,
Kindly describe the issue you are facing to enable us to help you.
Share the error is possible
  Moturi George,     Developer Advocacy and Support,  ADN Open
Storm_Clayton
Hello everyone,
I am currently facing a compilation issue with my .DLL file for Autodesk Revit 2025. Despite following the official documentation and relevant examples, I am encountering errors during the build process. Notably, this issue did not occur in previous versions of the product.
Here are the specifics of my setup:
  • Development Environment: Visual Studio Community
  • Revit Version: 2025.3
  • Error Messages: "You cannot directly start a project with a class library output type. To debug this project, you need to add an executable solution that references the class library project. Set the executable project as the startup project."
sragan
