Rebar Array Length in API does not match actual array length in model
longt61
longt61
I was testing a small app and find out that the rebar array length that was saved in RebarShapeDrivenAccessor does not match the actual array length in Revit model. This is the first time I have encountered this problem.
The value I got when apply dimesion in model is 3952mm or 12.966 ft.
The value I got from Revit Lookup and API is 3904mm or 12.808 ft.
I am using Revit 2019.2 if it helps. Please check out the attached file for more detail.
What are the reasons behind this?  Is there anything that I should know about Revit rebar?
longt61
I am not sure why I couldn't attached a .rvt file.  If any of you need it for further inspection, please let me know and I 'll email you the file. Thank you all for your time.
hanywillim
Bro, May you share with the Python API code to get the array length for a rebar?
