To output a View from View3D
This code:
__revit__.ActiveUIDocument.ActiveView
 Output:
<Autodesk.Revit.DB.View3D object at 0x00000000000001BF [Autodesk.Revit.DB.View3D]>
But I want the result of 'Autodesk.Revit.DB.View'....
I need your advice...! Thanks:)
Moustafa_K
View asview = __revit__.ActiveUIDocument.ActiveView as View
try something like the above. VIew3D class is inherited from View, so casting that to its parent class should be possible
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Thank you for your reply..!!
But I'm using Python so I'm sorry I couldn't apply your reply...:(
If there's any way you can at Python, please answer again...!!
jeremytammik
You question is a basic Python question.
You are trying to convert from a derived class to its base class.
This is normally never necessary, since it happens automatically when needed.
If you really want to do it explicitly, search the Internet for 'upcast in python':
https://duckduckgo.com/?q=upcast+in+python
Jeremy Tammik
Developer Technical Services
The Building Coder
