Is TessellatedShapeBuilder supported line segment?
katsh7
katsh7
I did google search as possible(end up this forum anyway :p), and probably seen all of the related Jeremmy's blog posts and still can't find the answer.
I managed to create a 3 points face(a triangle) and 4 points face(quad) and draw those geometry on the revit viewport applying arbitrarily materials by using TessellatedShapeBuilder and DirectShape.
But I really want to achieve now is to create "a line" material applied.
The reason why am I want to do is that I am making an addin that render some heat analysis results onto revit.
I have to draw lines with colors.
I am thinking a solution that draw a "narrow quad" to express line segments or curves, but it seems not a very good solution.
jeremytammik
I am asking the development team for you... hang on...
Jeremy Tammik
Developer Technical Services
The Building Coder
katsh7
I appreciate it.
jeremytammik
The development team replied:
No, it is intended for faces, not lines.
Sorry.
You might be better off using model lines rather than thin faces. I suggest you try both and benchmark your results.
Please let us know how you end up solving this. Thank you!
Jeremy Tammik
The Building Coder
katsh7
First of all, I appreciate your efforts.
I understand.
"Model line" is a good idea(I believe you mean model line as wireframe of the model).
I realize that I can represent  a contour and a vector by model lines. Line segment is not an only way to do that.
I will post the result but it will take a while, maybe around Jan. 2020.
Again, Thank you.
