Pyrevit toolbar extension, can you color the panel?
nlgMU4UN
nlgMU4UN
Hi im creating a toolbar via. learnrevitapi.com
and im wondering how do you change the color of the panel (the marked area)
im using pycharm
Like this:
lee6800
you might be better off asking this on pyrevit forum
https://discourse.pyrevitlabs.io/
I beliver this can be achived by placing a "yaml" file within the panel folder
search for background in this page https://pyrevitlabs.notion.site/pyRevit-Bundles-12323e3090904d9aa7cdc3d82095d3e3#1322635d84f447019ac...
lee6800
Here is an example,
in the yaml file i have:
background:
    title: '#00ffff'
and here is the result
nlgMU4UN
Thx 🙂
Bramdejong1985
Observer
Observer
This can be achieved by adding a background color in the bundle.yaml file for each panel in your tab.
this is an example from mine:   (see the screenshot)
title:
  en_us: BDJ-Dynamo
layout:
  - 1 - menu
  - 2 - BDJ2
  - 3 - Controls
  - 5 - Views
background:
  title: '#4d74b78a'
# set background for all parts
#background: '#ff0000'
# or for individual parts
#background:
  #panel: '#ff0000'
  #title: '#00ff00'
  #slideout: '#0000ff'
author: Bram de Jong (IDG)
you can either set a color for the entire background of the panel, or you can specify which color the Title needs to be (as Ive done in my toolbar), the panel itself and the slideout (if you have one)
Hope this helps and makes sense.
PS:  I use https//rgb.to for colors.
Remember that adding ff in front of your HEX coloring gives you a non-transparant color, while adding 4d in front, it gives a slightly transparant color.
Rafael_MartinezV
@Bramdejong1985
could you explain a bit more on the FF vs 4d?
I tried using the website you mentioned but confused as to how to make the colors transparent.
for instance, red
#ff0000 would be #4d0000? but i get a dark purple brown color
is this right?
Rafael_MartinezV
nevermind, i was able to figure out the meanings
