Wpf swap between documents
sonicer
sonicer
I have a modal WPF form with a ComboBox component that loads all dimension types in the project. When I switch to a different active project, is it possible to update the ComboBox source?
I tryed ViewActivated event. But It doesn't work.
Does anyone have a sample project I could use for inspiration?
thx.
ctm_mka
you would need to switch the active document first (Document Opened event maybe?) then ping your ViewActivated event.
TripleM-Dev.net
Check the SDK samples.
Also what doesn't work with ViewActivated exactly?
Keep in mind the event is raised for each view activated change, even of the same document!
I use it, but to reduce updating the Combox on each changed view, cache the document Hash (document.GetHashCode) of the last update. If the document in the current ViewActivated event is equal then don't update the ComboBox.
If you also need live update of it's content when new types are created, renamed, or deleted you will need to check additional events
- Michel
