Converting text to geometry when performing a 2d view export
haroon.haider39ZXL
haroon.haider39ZXL
We have been able to get access to the lines, grids, annotations and other basic elements of a 2d view (using the  IExportContext2D interface).  Is there a way to convert the annotation text from strings to geometry using Revit API similar to how you can do it in AutoCAD ?
I'm looking to get something like the attached image.
jeremy_tammik
You could take recourse to a pixel image, if all else fails...
haroon.haider39ZXL
Update: I ended up getting what I need by processing a TextNode from the export context method OnText() call.  There is enough information in the text node class to be able to convert it to a GraphicsPath and pull out the geometry from there.
jeremy_tammik
Thank you for confirming! I added your note of your solution to the blog:
https://thebuildingcoder.typepad.com/blog/2022/01/detailed-2d-text-and-other-element-geometry.html#3
olena_havatiuk
Im really appreciate for your info, many thanks!!
revitapi99
Community Visitor
Community Visitor
Hi @haroon.haider39ZXL
Can you please elaborate how you have converted TextNode to GraphicsPath, I want to export the text geometry and I want to extract text path points.
