project units
project units
Moshe-A
Mentor Mentor
project units
Moshe-A
Guys Hi,
i am retrieving the Project Base Point and i would like to format it according to the current Project Units
here is my simple code:
namespace MyNameSpace
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document document = commandData.Application.ActiveUIDocument.Document;
            ProjectLocation projectlocation = document.ActiveProjectLocation;
            XYZ origin = new XYZ(0, 0, 0);
            ProjectLocation position = projectlocation.get_ProjectPosition(origin);
            double angle = position.Angle;
            double eastWest = position.EastWest;
            double northSouth = position.NorthSouth;
            Units units = new Units(UnitSystem.Metric);
            FormatValueOptions formatvalueoptions = new FormatValueOptions();
            FormatOptions formatoptions = new FormatOptions();
            formatoptions = units.GetFormatOptions(UnitType.UT_Length);
            formatvalueoptions.SetFormatOptions(formatoptions);
            string s1 = UnitFormatUtils.Format(document.GetUnits(), Autodesk.Revit.DB.UnitType.UT_Length, eastWest, false,   false, formatvalueoptions);
            string s2 = UnitFormatUtils.Format(document.GetUnits(), Autodesk.Revit.DB.UnitType.UT_Length, northSouth, false, false, formatvalueoptions);
            return Autodesk.Revit.UI.Result.Succeeded;
can i get the UnitSystem from the project?
s1 + s2 are set to be "0", what am i doing wrong?
(i do not want to set each FormatOptions properties, i would like them to inherit from Units)
if there is another way to do this?
thanks in advance
Moshe
Moshe-A
Good Morning,
forgot to mention...i did moved the Project Base Point from Survey Point/Startup Point
Moshe-A
here is an update
i think i figure it out  (working on Revit 2015)
return EastWest and NorthSouth only if the Project Base Point was moved cliped
it will returns the origin point (0, 0, 0) if the Project Base Point was moved unclipped
is this a bug? or that's how it works?
another issue is:
formatoptions.DisplayUnits = units.GetFormatOptions(UnitType.UT_Length).DisplayUnits;
this return DUT_MILIMETERS even if the project units is in CM or Meter
again is this a known bug?
FAIR59
for projectunits try:       Units units= document.GetUnits();
Moshe-A
yes i did that
i have pretty much solved all my issues, the only issue left is this:
is this a bug? or that's how it works?  (in Revit 2015)
