Forge API vs Revit API: RVT Detail
jpryne
jpryne
 I've been looking at the Forge API as a means of accessing data about Revit files, and am coming to the conclusion that the Forge API is fairly limited in what specific information it can provide about a given RVT file. In other words, if I need to access very specific information about, say, nailing schedule call-outs on a sheer-wall, might I be able to access such annotations vie the Forge API or would I need the Revit API? Either way, what are some examples of data that the Forge API would overlook?
jeremytammik
Please bear in mind that Forge is a totally generic system built to handle CAD models from absolutely all design and modelling system seed files.
Therefore,only generic data is directly supported, e.g., geometry, properties and certain element relationships and hierarchies.
If you need specific BIM related information, you will almost certainly be better off accessing and extracting that using the Revit API.
It is extremely easy do combine data from any source in the world with the data made available by the Forge system, so there is nothing stopping you from combining the two approaches.
In fact, a number of the official Forge samples demonstrate that very approach, notably the Responsive Connected Database sample:
https://github.com/Autodesk-Forge/forge-rcdb.nodejs
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
