Problems installing Revit.
serg
serg
Hello. The problem when starting Revit, it was required to download the Revit server file, installed, to no avail. What other steps are needed to install it? For the third day I can not install! Revit 2019 education version. I also completely removed it, cleaned the registries, then installed it. Drive C was full, I had to move it to drive D, it was my mistake.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @serg ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
serg
Hello. I already wrote everywhere, I did not wait for a concrete answer. Thank.
