Design options from linked models in host model
Can we recover the name of design options in a host model? This is the case when the revit modeller has not kept track of the chosen design options when he/she linked the revit models to the host model. I am trying to recover the names of the design options from the host model.
Thank you in advance.
jeremy_tammik
Maybe you can filter for all BIM elements in the host model, read all their DESIGN_OPTION_PARAM or DESIGN_OPTION_ID values and create a list from that somehow.
All I know is that retrieving a list of the design options was tricky enough in Revit 2015 to render it almost impossible:
https://thebuildingcoder.typepad.com/blog/2015/03/list-and-switch-design-options-using-ui-automation...
jeremy_tammik
Another mention of inaccessibility:
https://thebuildingcoder.typepad.com/blog/2017/11/revit-api-panel-au-las-vegas-2017.html
Q: Have a requirement to accept design options on the project.
A: Not exposed on the API, but just accept design option is easier, but needs to be on Revit Ideas.
