- Mute
- Permalink
- Report
Hello everyone, when I use printManager. SelectNewPrintDriver, then the dpi settings are reset, can this be avoided?
Yes, but you have to do it outside Revit
use the following steps. Search Windows for devices, and click Devices and Printers in the list of results. Right-click the printer icon () for your printer, and then select Printing preferences. Select your new default print settings (paper size, orientation, etc.), and then click OK.
below is a video for a HP printer but is basically the same for any other brand if the printer is managed by the network administrator, you may need to do this changes on the server print config.
https://youtu.be/-NC0j1cJAgQ?t=48
Hope it helps 🙂
