Replace a family using its transform.
rpowers
Message 1 of 1
rpowers
I'm trying to find the easiest method of swapping one family for another. Specifically pipe fittings of dissimilar "Part Types" . For example, i need to be able to swap a 3 port Tee to a Multi-Port (I'll say Tee) where by the Main Branches are the same but the multi-port fitting has bosses. All fittings are drawing in the same orientation so it would be ideal if I could just match the transform of the original part. Any help on getting the transform matching would be most appreciated.
Replies (0)
