Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
problem while implementing AvailabilityClassName?
1 REPLY 1
prasannamurumkar
436 Views, 1 Reply
prasannamurumkar
i have dll and command name which is calling on button.
I want to enable button at zero document state. for that i am using AvailabilityClassName
when  i give name in AvailabilityClassName. .while running it shows error as class has not inherit the IexternalCommandAvailability.
I know it is require to implement Iexternal Availavbility in that class.
But i have only dll and command. class is not available with me.How can  implement
AvailabilityClassName property?
1 REPLY 1
jeremytammik
Use an IL disassembly tool to explore and determine the exact class name in the .NET assembly DLl:
https://duckduckgo.com/?q=il+disassembly
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Jeremy Tammik
The Building Coder
