PostCommandId equals UNDO
Hello friends I have big question. When I want to sign PostcommandId equals UNDO = 33032, I have an exception:
"The Revit command id cannot be assigned a command binding." but when I sign another command there is not happen any exceptions. Why is happened to this command? And how to do it right? This is my code:
First decision:
RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.Undo);
AddInCommandBinding importBinding = a.CreateAddInCommandBinding(commandId); (An exception occurs here)
importBinding.BeforeExecuted += new EventHandler<Autodesk.Revit.UI.Events.BeforeExecutedEventArgs>(Undo);
Second  decision:
RevitCommandId commandId = RevitCommandId.LookupCommandId("ID_BUTTON_UNDO");
jeremytammik
Maybe Undo is an exception, intentionally?
What does CanPostCommand report for Undo?
Jeremy Tammik
Developer Technical Services
The Building Coder
Sean_Page
I would suggest that you check to make sure that it can have a binding before trying to add an event handler.
if(commandId.CanHaveBinding)
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
