How to get column height
alexandra.anton34WM4
There is any possibility to get the column height using API?
I also need to extract column Constraints.BaseOffset and Constraints.TopOffset
It is possible to do this through API?
Thank you.
jeremytammik
Yes, very easily indeed.
Please work through the Revit API getting started material to understand the basics and enable you to create your first Revit add-in:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That also explains how to access and read parameter values of elements.
The data you seek is stored in parameters, like most Revit BIM information.
You can use RevitLookup to explore exactly where:
https://github.com/jeremytammik/RevitLookup
Jeremy Tammik
Developer Technical Services
The Building Coder
studio-a-int
You just need to collect all Structural Columns in your project using a FilteredElementCollector:
structuralColumns = FilteredElementCollector(doc).WhereElementIsNotElementType().OfCategory(BuiltInCategory.OST_StructuralColumns).ToElements()
If you want to filter based on specific properties, add a filter.
Then go through your collection and pull the parameters you are looking for such as:
columnLength = i.get_Parameter(BuiltInParameter.INSTANCE_LENGTH_PARAM).AsDouble()
baseOffset = i.get_Parameter(BuiltInParameter.SCHEDULE_BASE_LEVEL_OFFSET_PARAM).AsDouble() # or .AsValueString() if you just want to "print" the data.
all the parameters you are looking for a Built In Parameters.
