Get material image path from Ceramic Schema
lavicka.milan
lavicka.milan
I am trying to get all image material path from project materials.
Thanks to Jeremy: https://thebuildingcoder.typepad.com/blog/2017/10/material-texture-path.html
https://thebuildingcoder.typepad.com/blog/2019/04/set-material-texture-path-in-editscope.html
I was able to get a image path from Generic schema asset.
            FilteredElementCollector fec
                = new FilteredElementCollector(doc);
            IEnumerable<Material> targetMaterials
              = fec.OfClass(typeof(Material)).OfType<Material>();
            List<string> mat = new List<string>();
            foreach (Material material in targetMaterials) {
                using (Transaction t = new Transaction(doc)) {
                    t.Start("Change texture path");
                    try
                        ElementId appearanceAssetId = material.AppearanceAssetId;
                        AppearanceAssetElement appearanceAssetElem
                            = doc.GetElement(appearanceAssetId) as AppearanceAssetElement;
                        mat.Add("appearanceAsset "+appearanceAssetElem.Name.ToString());
                        using (AppearanceAssetEditScope editScope
                            = new AppearanceAssetEditScope(doc))
                            Asset editableAsset = editScope.Start(appearanceAssetId);
                            mat.Add("editableAsset "+editableAsset.Name.ToString());
                            AssetProperty assetProperty = editableAsset.
                                FindByName("generic_diffuse");
                            Asset connectedAsset = assetProperty.
                                GetSingleConnectedAsset() as Asset;
                            mat.Add("ConnectedAsset "+ connectedAsset.Name.ToString());
                            if (connectedAsset == null)
                                assetProperty.AddConnectedAsset("UnifieldBitmap");
                                connectedAsset = assetProperty.GetSingleConnectedAsset();
                            else
                                AssetPropertyString path = connectedAsset.
                                    FindByName("unifiedbitmap_Bitmap")
                                    as AssetPropertyString;
                                mat.Add("Path "+path.Value.ToString());
                    catch (Exception ex) {
                    mat.Add("-------------------------");
                    App.WriteToTxt(mat);
                    t.Commit();
                    t.Dispose();
For the test purpouse I have created project with 5 materials. 3of them are creating manualy using .png from user/desktop folder. And another two are downloaded form Autedesk material library using images from: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\2\Mats.
Here is a Log file from this code.
You can see there is a problem with CeramicSchema(Autodesk Material Library).
So is there a way to get image path from this materials?
2.) what does ["string"] stand for, for example in: connectedAsset["unifiedbitmap_Bitmap"] , because when I write it like this, error: "cannot convert from string to int"pop out
jeremytammik
To address your question two: in the term connectedAsset["unifiedbitmap_Bitmap"] , I would assume that connectedAsset is a dictionary, and it takes string-valued key, so "unifiedbitmap_Bitmap" is the key string to look up in the dictionary.
Have you analysed your model using RevitLookup?
You should be able to navigate to this data and explore interactively what entries are available and what keys are being used.
Jeremy Tammik
Developer Technical Services
The Building Coder
danielpinheiro860
Very great solution! Thank you. I used your solution and tried to use a workaround related with your question two, iterating over the AssetProperty twice (I dont know if this is the best pratice) but for the sake of some contribution, I am sharing the code, it worked well for me:
 public void FindTextureBitmapPaths(Document doc)
                try
                    AppearanceAssetElement appearanceAssetElem = doc
                    Asset asset = appearanceAssetElem
                        .GetRenderingAsset();
                    int size = asset.Size;
                    for (int assetIdx = 0; assetIdx < size; assetIdx++)
                        AssetProperty aProperty = asset[assetIdx];
                        if (aProperty.NumberOfConnectedProperties < 1)
                            continue;
                        Asset connectedAsset = aProperty
                          .GetConnectedProperty(0) as Asset;
                        if (connectedAsset.Name == "UnifiedBitmapSchema")
                            size = connectedAsset.Size;
                            for (int assetIdx2 = 0; assetIdx2 < size; assetIdx2++)
                                aProperty = connectedAsset[assetIdx2];
                                if (aProperty.Name == "unifiedbitmap_Bitmap")
                                    AssetPropertyString path = connectedAsset[assetIdx2] as AssetPropertyString;
                                    break;
                catch { }
