Plugin Auto Start When Revit Is Opened
oguzkomcu
oguzkomcu
I have an application that I developed myself. Actually in this application I am trying to convert rvt file to svf or gltf file format. In line with the request for this, I want the desired rvt file to be opened and the ExportGltf plugin to start automatically and complete the export process. How can I do that ?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @oguzkomcu ,
Please take a look at the below code
class App : IExternalApplication
        public static UIControlledApplication uiControlledApp = null;
        public static UIDocument uidoc = null;
        public static Document doc = null;
        public Result OnStartup(UIControlledApplication application)
            uiControlledApp = application;
            uiControlledApp.Idling += onIdling;
            return Result.Succeeded;
        private void onIdling(object sender, IdlingEventArgs e)
            UIApplication uiapp = sender as UIApplication;
                uiapp.OpenAndActivateDocument(@"C:\Program Files\Autodesk\Revit 2023\Samples\rst_basic_sample_project.rvt");
                 * Code to export Revit to gltf
            uiControlledApp.Idling -= onIdling;
        public Result OnShutdown(UIControlledApplication application)
Also, I found the below link
https://github.com/weiyu666/RevitExportObjAndGltf
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
oguzkomcu
1- There is no addin file in this github repo. Do I create the addin file? Or is there a different method?
2- I am very new to developing Revit Api. I've been dealing with this for weeks. How exactly do I need to process the gltf code there? Is there a sample code?
jonathan.taVCBM2
Hi ,
Have a look at this part of the guide , you can find it in the link here
Developers add functionality by creating and implementing External Commands and External Applications. Revit identifies the new commands and applications using .addin manifest files.
  • External Commands appear under the External Tools menu-button on the Add-Ins tab.
  • External Applications are invoked when Revit starts up and unloaded when Revit shuts down
Jonathan Talisman
BIM Developer
oguzkomcu
Hello good day. Even though I gave the correct namespaces of the classes and they are marked in green, I get a reference error, is it because of the revit version? Or is there another reason?
Error : The type or namespace name 'UIControlledApplication' could not be found (are you missing a using directive or an assembly reference?)
jonathan.taVCBM2
Hi @oguzkomcu ,
It's really hard to tell with no code sample, screen shots or anything of that sort.
Are you trying to run the code that @naveen.kumar.t  posted ? I am guessing you are missing some using statement.
Jonathan
Jonathan Talisman
BIM Developer
oguzkomcu
As you can see, I'm not actually missing a using statement. When I searched the internet for this problem, I saw that it was related to the .Net Freamwork version. When I upgraded my class library to 4.8, the errors went away. I then ran revit but got this error.
Error : System.TypeLoadException Could not load type ' RevitGltfDeneme3.App ' from assembly ' RevitGltfDeneme3 , Version 1.0.0.0 , Culture = neutral , PubliKeyToken = null " .
