Revit export gltf plugin error
oguzkomcu
oguzkomcu
This is my fault;
Method not found: 'System.String Autodesk.Revit.DB.View.get_ViewName()'.
I couldn't find anything online about this error.I would be very happy if someone answers.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @oguzkomcu ,
Looks like Revit Cannot find the method "get_ViewName()".
To get the View name, please use the below code
Autodesk.Revit.DB.View view;
string viewName=view.Name;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Kennan.Chen
The version of RevitAPI.dll you reference in your add-in project mismatches with the one Revit provides at runtime.
Autodesk.Revit.DB.View.ViewName is declared as obsolete in Revit 2019 and is permanently removed in Revit 2020.
Your add-in project might be referencing Revit sdk 2014-2019 and you try to run your add-in under Revit 2020-2022.
BTW, mismatching revit sdk version works good if the APIs you call is the same between the two versions. It only breaks if you use a changed API.
