Execute command in Group Environment.
ngvanphong2012
ngvanphong2012
I want to run command button in Group Edit.
Is there any way to do it?
Thanks you very much!
jeremy_tammik
No, probably not. Revit is single threaded, and you can only execute Revit API calls in a valid Revit API context, and such a context is only provided by Revit when it calls your add-in event handlers. Everything you do in the Revit API happens in an event handler. The most well-known one is IExternalCommand.Execute.
