Pick Point in 3D : how to pick on linked files ?
igor.barcelosC54YD
igor.barcelosC54YD
I have used the following solution for pick point in the 3D :
https://thebuildingcoder.typepad.com/blog/2011/11/pick-a-point-in-3d.html
Ok, that's works fine if I have just one model but I can not select faces on linked files.
Is there any workaround for this ?
The solution provided below is limited because as it only takes on element class and not faces.
https://thebuildingcoder.typepad.com/blog/2020/07/selection-link-support-cancel-custom-export-multit...
Any help ?
longt61
I think the second link has almost everything you need. You can just get the geometry object from the reference and determine if it is a face.
Just modify the selection filter class to make T inherit from Face then add these 2 lines after you get the element from link file
var geo = e.GetGeometryFromReference(r);
return geo != null && geo is Face;
igor.barcelosC54YD
