Parameters wich changes equally across different types in a family?
kjeboe
kjeboe
Hi!
Is this possible, and how:
Parameters wich changes equally across different types in a family.
For instance: a yes/no-parameter in a door family, change it in one type, then it changes in every type.
PA
pure.architect
http://www.purark.no
Dear,
Could you explain more. What you want?
kjeboe
I would like to be able to fill in a parameter under either properties or under family type and know that for all types and instances the parameter will be the same
pure.architect
Dear KB,
want to know parameter  name will be same or parameter value.
For parameter value: You have to create Type Parameter.
Note: Parameter name is same for all mapped category.
To creating parameter you watch below link.
http://spiderinnet.typepad.com/blog/2011/05/parameter-of-revit-api-31-create-project-parameter.html
http://thebuildingcoder.typepad.com/blog/2014/04/category-support-for-shared-type-and-instance-param...
I hope this will help you.
kjeboe
Thank you.
I'm not really sure if this is the answer to what I am looking for, but I will surely look closer at it..
pure.architect
