Can i know parameter type either shared or Project Parameter
Dear,
I can get list of All parameter from Document using.
BindingMap map = doc.ParameterBindings;
DefinitionBindingMapIterator it = map.ForwardIterator();
But i also want to know which parameter is shared or parameter that shown in below figure:
Is there is possibility. As i read various blog this is not exposed in API. Can we get using any trick?.
Charles.Piro
if you query an Element, you can know if the parameter is shared or not.
Parameter _param = Element.LookupParameter("NAME OF PARAMETER");
bool blIsShared = _param.IsShared;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
This is work when we have element. i do not have element.
I am getting parameter list from document which is in Project parameter from manage. while i modify using manage bar that show in Image i got parameter type either shared or project . But using API not able to decide which one is Project or shared.
At a glance, this looks like what you are trying to do.
http://jeremytammik.github.io/tbc/a/1388_project_param_guid.html
