Enclosed Region using Room Separator
How can I programmatically create an enclosed space using Room Separators and assign Room object to it. Can somebody provide a sample code to work with Room Separator.
atiefenbach
This should get you going:
public void CreateRoomAndSeperators()
	Document doc = this.ActiveUIDocument.Document;
	View activeView = doc.ActiveView; //You should make sure you're in a Plan View
	XYZ pt1 = new XYZ(0, 0, 0);
	XYZ pt2 = new XYZ(0, 10, 0);
	XYZ pt3 = new XYZ(10, 10, 0);
	XYZ pt4 = new XYZ(10, 0, 0);
	UV pt5 = new UV(5, 5);
	CurveArray curveArray = new CurveArray();
	curveArray.Append(Line.CreateBound(pt1, pt2));
	curveArray.Append(Line.CreateBound(pt2, pt3));
	curveArray.Append(Line.CreateBound(pt3, pt4));
	curveArray.Append(Line.CreateBound(pt4, pt1));
	using (Transaction trans = new Transaction(doc))
		trans.Start("Create Room and Boundaries");
		ModelCurveArray lines = doc.Create.NewRoomBoundaryLines(activeView.SketchPlane, curveArray, activeView);
		Room room = doc.Create.NewRoom(activeView.GenLevel, pt5);
		//now modify the "room" Element's Name, Number, etc.
		trans.Commit();
Anthony Tiefenbach
BIM Manager
HuntonBrady Architects
JimJia
Yes, NewRoomBoundaryLines() is the answer!
Thanks Anthony's code!
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
MiguelGT17
Some how the code doesnt work if I set the current view as a 3D view. Indeed, the following issue pops up:
Tabeer_Tariq
Community Visitor
Community Visitor
Can this be done using dynamo only?
AnthonyTiefenbach
I’m sure it’s possible, but you’d probably get a better answer in a Dynamo forum.
