Opening Form during PromptForFamilyInstancePlacement
devX6MRR
devX6MRR
Hi everyone,
I'm trying to open a window with some option during the PromptForFamilyInstancePlcement.
I know that it's possible only if i start the window showing before the calling of the method.
The problem is the first time i show the window the command works fine, but if have a second call shortly after the first one the command exits without starting the prompt.
Debugging my code i figured out it's the window the problem, without it i don't have any problems, but i can't find out the reason of this behaviour.
So you have any idea about it?
Giorgio
Mustafa.Salaheldin
This is probably because you just hide the window, you have to kill it, use window.dispose or window.close.
If this reply satisfies your need please mark it as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
