Open Source Ifc Property Viewer
GeomGym
Message 1 of 10
GeomGym
I'm involved in an open source project that might be of interest and benefit to other Revit API developers.
It's available in an infant form at https://github.com/jmirtsch/RevitIfcPropertyBrowser
Primarily it's a replica of the Revit property browser, when you select a single element or multiple elements, it displays the appropriate IFC properties as would be generated when exporting to IFC (Industry Foundation Class openBIM format).  An image is below.
There are many planned improvements for this project, including the ability to edit the revit parameters from the IFC properties (which permits the opportunity for some more interesting user interface controls for doing so).
I will be posting some related questions and suggestions here in the following posts.
Cheers,
Jon
Replies (9)
Message 2 of 10
GeomGym
First question related to the property browser.  It works well in the event of a user selecting an element (or multiple).
But I can't find any way to detect when elements are unselected.  The browser retains the previous state.
Any suggestions for changes to the code to identify this situation?
Jon
Message 3 of 10
Currently, I'm doing it by using the Idling event.
UiControlledApplication.Idling += OnIdling;
internal static void OnIdling(object sender, IdlingEventArgs args) { var uiApplication = (UIApplication) sender; if (uiApplication.ActiveUIDocument == null) return; var selection = uiApplication.ActiveUIDocument.Selection; var oldValues = _selectedIds; var newValues = selection.GetElementIds(); //Do what you want next }
from there, you can retreive old selection, new one, compare them, and know what elements are selected/unselected
Message 4 of 10
GeomGym
That's a great suggestion.  I will look at implementing it ASAP.
Message 5 of 10
aignatovich
Hi!
You are already using IExternalEvent. It can be raised from whatever you want, for example by .Net timer or another thread. I don't like Idle event and I am trying to avoid it due to performance reason.
Message 6 of 10
I mostly agree with you.
Idling event must be used with caution. Each registered event will be called repeatedly, unless you let the event remove itself. So you shouldn't register an event with an heavy workload. However, comparing selected ids is rather quick, and it's possible to do it in an async task.
Moreover, if you need a a specific context that need to be constantly updated following the user selection, the idling event is probably the best way to do it.
Message 7 of 10
 public static class RevitSelection
        private static int[] _selectedIds = new int[0];
        public static EventHandler<RevitSelectionChangedArgs> SelectionChanged;
        internal static Selection Selection { get; private set; }
        public static int[] SelectedIds
            get => _selectedIds;
            set
                if (oldValues.All(value.Contains) && oldValues.Length == value.Length)
                    return;
                _selectedIds = value;
                Selection.SetElementIds(_selectedIds.Select(e => new ElementId(e)).ToArray());
                SelectionChanged?.Invoke(null, new RevitSelectionChangedArgs(oldValues, value));
                return;
            Selection = uiApplication.ActiveUIDocument.Selection;
            var newValues = Selection.GetElementIds().Select(e => e.IntegerValue).ToArray();
            if (oldValues.All(newValues.Contains) && oldValues.Length == newValues.Length)
                return;
            _selectedIds = newValues;
            SelectionChanged?.Invoke(null, new RevitSelectionChangedArgs(oldValues, newValues));
    public class RevitSelectionChangedArgs : EventArgs
        internal RevitSelectionChangedArgs(int[] oldSelection, int[] newSelection)
            OldSelection = oldSelection;
            NewSelection = newSelection;
        public int[] OldSelection { get; }
        public int[] NewSelection { get; }
This is the selection context class that I'm using in my plugin. It always worked well without performance issues for me.
Message 8 of 10
duncan.lithgow
@GeomGym
Hi Jon, does anything like this exist now?
Message 9 of 10
GeomGym
Sorry, I haven't touched this particular project in some time, and there's a few other developments that are a higher priority to pursue at present.  It is open source, so it should still work and others can work on it.
Message 10 of 10
duncan.lithgow
@GeomGym with the current interest in incremental exchange of partial IFC data this is going to become more important.
https://community.osarch.org/discussion/comment/12981/#Comment_12981
https://github.com/brunopostle/ifcmerge
