Room Separation Line - Associated Level
gprofile
gprofile
Is it possible to get the associated level of a Room separation Line by creating a simple Macro, as it isn't available in the properties.
I checked in the Revit 2017.1 API documentation but couldnt find  anything related to Room Separation Line.
You should be able to get the owner view, cast it as ViewPlan and get the Level from the view plan.
 var viewPlan = (ViewPlan) Document.GetElement(modelCurve.OwnerViewId);
 var level = (Level) Document.GetElement(viewPlan.LevelId);
FAIR59
the room separation line can be visible in floorplans of a different level, or even in 3D views.
this will sound a bit hacky, but the name of the sketchplane of the separationline is equal to the name of the level.
                SketchPlane sk = modelcurve.SketchPlane;
                IEnumerable<Level> levels = new FilteredElementCollector(doc)
                	.OfClass(typeof(Level))
                	.Cast<Level>()
                	.Where( l => l.Name.Equals(sk.Name));
                Level LevelofLine = levels.FirstOrDefault();
another approach would be to find the level by the height from the sketchplane.Plane  [ height = sk.GetPlane().Origin.Z ]
gprofile
Excuse me for my ignorance in C# i tried the code below but couldn't solve the error
Error CS0039: The Autodesk.Revit.DB.GeometryObject type cannot be converted to Autodesk.Revit.DB.ModelCurve with a reference conversion, boxing conversion, unboxing conversion, wrapping conversion, or NULL type conversion.
UIDocument uiDoc = this.ActiveUIDocument;
Document doc = uiDoc.Document;
Reference myRef = uiDoc.Selection.PickObject(ObjectType.Element);
Element ele = doc.GetElement(myRef);
GeometryObject geomObj = ele.GetGeometryObjectFromReference(myRef);
ModelCurve modelcurve = geomObj as ModelCurve;
IEnumerable<Level> levels = new FilteredElementCollector(doc).OfClass(typeof(Level)).Cast<Level>().Where( l => l.Name.Equals(sk.Name));
Level levelOfLine = levels.FirstOrDefault();
Please guide me.
FAIR59
The GeometryObject is not needed.
you can get the modelcurve directly:
ModelCurve modelcurve = doc.GetElement(myRef) as ModelCurve;
gprofile
I cannot understand why this code throws a null Exception, when I select a Line
			Element e = doc.GetElement(myRef);
			ModelCurve modelcurve = e as ModelCurve;
			var viewPlan = (ViewPlan) doc.GetElement(modelcurve.OwnerViewId);
 			var level = (Level) doc.GetElement(viewPlan.LevelId);
 			TaskDialog.Show("Level is : ",e.Name + level.Name);
FAIR59
a room separation line is a model element, and as such it doesn't have a OwnerView. ( Only annotation elements have a Ownerview.)
so
modelcurve.OwnerViewId = ElementId.InvalidElementId, resulting in doc.GetElement(modelcurve.OwnerViewId) = null
