Open Existing .Rvt File
Message 1 of 9
I feel silly having to ask, but I can't find a method in the RevitAPI type
library or in any of the Revit code samples that allows you to open an
existing .rvt file by supplying the full path. Can someone point me in the
right direction please?
Replies (8)
Message 2 of 9
You're not crazy - it's not there...
Pretty much everything in the Revit API is in "Current Document Context"...
Message 3 of 9
This is not the case, you are able to create a new project/document in revit.
Message 4 of 9
Please share with us how to do this.
wrote in message news:5307246@discussion.autodesk.com...
revit.
Message 5 of 9
Are you ADN member? Has ADSK provided this function in their new version API?
Message 6 of 9
I still don't see it...
(but here's hoping...)
Message 7 of 9
Does anyone know if this is still the case, not having the ability to open an existing rvt file through the API?
Thanks in advance,
Don
Message 8 of 9
Yes, it was added a while ago... Certainly Revit 2008 had it.
Application.OpenDocumentFile( string filename )
-Matt
Message 9 of 9
Thanks Matt
