Obtain Sync With Central Number Via API?
DJB_CADfx
DJB_CADfx
When using a Workshared environment, a *.slog file is created in the Backup sub-folder. Each time a sync with central occurs, a line is written in the slog file that contains the Number of that particular synchronization (starts at 1 and increments up each time another sync is performed).
We have a Revit addin that fires upon Sync Completion. Is there any way from that event to make an API call that will tell us what the specific number of that Sync was that just occurred? (We would like to stay away from reading the file itself if possible so we don't run into any of the problems associated with file system reading in a multi-user environment like this.)
Dave Blackburn
dantartaglia8696
Hi Dave,
I do not believe so except to either keep a counter in your logic or read the slog file when a sync happens.
Dan Tartaglia
JimJia
Dear David Blackburn,
Please accept our sincerer apology for the delay! We had a backlog in the queue these days.
Revit API doesn't provide such API except events DocumentSynchronizingWithCentralEventArgs and DocumentSynchronizedWithCentralEventArgs which doesn't provide Number option you desired, sorry if this is a bad news to you.
However, it should not be problem to read file with multi users, you can refer to this stakoverflow page or similar: http://stackoverflow.com/questions/3527205/multiple-threads-reading-from-the-same-file
Hope it's helpful.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
