trouble getting a list of WallType objects that are usable
Message 1 of 13
Im really thrashing about attempting to get a collection of WallTypes in the revit api. I dont want a list of WallTypes that are currently in the document (assume that the document is a blank template) im trying to use the Wall.Create(Document, Curve, ElementId, ElementId, Double, Double, Boolean, Boolean) method to place a wall of a given WallType (which of course has an ElementId) and I cannot seem to get a proper container of the things. FilteredElementCollector does not return anything useful! assistance appreciated.
Replies (12)
Message 2 of 13
Message 3 of 13
dantartaglia8696
It's been a while since I've extracted wall types. The below came from an older app:
FilteredElementCollector collector = new FilteredElementCollector(Command.doc);
FilteredElementIterator itor = collector.OfClass(typeof(Autodesk.Revit.DB.HostObjAttributes)).GetElementIterator();
// Reset the iterator
itor.Reset();
// Iterate through each family
while (itor.MoveNext())
intCntr++;
// Get the current family
Autodesk.Revit.DB.HostObjAttributes oSysFamilySymbol = itor.Current as Autodesk.Revit.DB.HostObjAttributes;
if (oSysFamilySymbol != null)
Message 4 of 13
neither of these works in revit 2016.
here's a snippet:
UIApplication uiApp = commandData.Application;
var doc = uiApp.ActiveUIDocument.Document;
var collector = new FilteredElementCollector( doc );
var familyCollector = collector
    //.OfClass( typeof( HostObjAttributes ) )
    .OfCategory( BuiltInCategory.OST_Walls )
    .ToElementIds()
    .Where( x => x != ElementId.InvalidElementId );
if ( familyCollector.Count == 0 ) {
message = "no family loaded!";
return Result.Failed;
both of these examples have this snippet only error out.
Message 5 of 13
I should probably mention that i need the elementIds of valid walls are needed as I'm using
method
Message 6 of 13
dantartaglia8696
The below retrieves WallType objects in my Revit 2016 model:
private List<WallType> WallTypesGet(Document doc)
List<WallType> oWallTypes = new List<WallType>();
try
FilteredElementCollector collector = new FilteredElementCollector(doc);
itor.Reset();
Autodesk.Revit.DB.HostObjAttributes oSystemFamilies =
if (oSystemFamilies == null)
continue;
// Get the family's category
Category oCategory = oSystemFamilies.Category;
// Process if the category is found
if (oCategory != null)
if (oCategory.Name == "Walls")
WallType oWallType = oSystemFamilies as WallType;
if (oWallType != null)
oWallTypes.Add(oWallType);
return oWallTypes;
catch(Exception ex)
MessageBox.Show(ex.Message);
return oWallTypes = new List<WallType>();
Message 7 of 13
testing that oWallTypes isn't empty (using the Count property of collections) fails. so this method doesn't work either.
Message 8 of 13
you know it would probably help if i mention that I'm using revit 2016 R2 😛 sorry if that caused any confusion.
Message 9 of 13
dantartaglia8696
Hi James,
The method I sent you works correctly for me in R2. What error(s) are you getting in the catch()? Can you send a simple example of one of your RVTs that you have the error in?
Message 10 of 13
dantartaglia8696
Here is a recording of my code working for me.
Message 11 of 13
odd, I'm essentailly embedding your code into a loop that should put up walls from baked values.
var collector = new FilteredElementCollector();
try {
var itor = collector
    itor.Reset();
    while ( itor.MoveNext() ) {
            = itor.Current as HostObjAttributes;
        if ( oSystemFamilies == null ) {
            continue;
        if ( oCategory != null ) {
            if ( oCategory.Name == "Walls" ) {
                if ( oWallType != null ) {
                    oWallTypes.Add( oWallType );
} catch ( Exception ex ) {
    message = ex.Message;
if ( oWallTypes.Count == 0 ) {
    message = "no wall families loaded!";
Message 12 of 13
dantartaglia8696
Does my code work for you unaltered?
Message 13 of 13
yes, but I'm not sure why my code doesn't work. let me get back to you in a bit.
