objects in ifc not visible - revit 2019
Hi, Ive an issue with linking ifc to revit. When ifc-file is linked to revit, no objects is visible and/or is able to turn on in visibilitygarphics. An error message is shown when file is linked, "Boolean error cutting IFCBOOLEANRESULT (#38637) with IFCBOOLEANRESULT (#38647)"
I can open ifc in for example Tekla viewer, there objects is visible.
Can someone help me with this?
jeremytammik
Dear Rasmus,
Thank you for your query.
Are you doing anything programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
