Good Day,
I'm having difficulty creating a line based family instance on the geometry of a curtain panel, On a wall it works perfectly.
I have tried using geometry from symbol and instance with no luck. If posable could you anyone please provide code that is able to draw a line based family on the front face of the curtain wall using the face edge for the line.
Thank You.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
Selection selection = uidoc.Selection;
var app = commandData.Application;
using (Transaction tx = new Transaction(doc, "Place Family"))
tx.Start();
// Get face and ensure it has references
Reference faceRef = selection.PickObject(ObjectType.Face, "Select a face");
// Get edge
Reference edgeRef = selection.PickObject(ObjectType.Edge, "Select an edge");
Element edgeElem = doc.GetElement(edgeRef);
Edge edge = edgeElem.GetGeometryObjectFromReference(edgeRef) as Edge;
Line line = edge.AsCurve() as Line;
var symbol = new FilteredElementCollector(doc)
.OfCategory(BuiltInCategory.OST_StructuralStiffener)
.WhereElementIsElementType()
.First() as FamilySymbol;
doc.Create.NewFamilyInstance(faceRef, line, symbol);
tx.Commit();
return Result.Succeeded;
