Hi @Moustafa_K,
thanks already for your help!
I still have some issues with the references. When I use my Add-in in Revit2025 I receive the following error:
This is a part of my code where I implemented the RebarBendingDetail.AddHosts on line 75:
IList<Reference> rebarRefs = new List<Reference>();
// Place rebar bending detail for all rebars with style Standard
for (int i = 0; i < RebarsStandard.Count; i++)
Element rebarElem = RebarsStandard[i];
Rebar rebarStandard = rebarElem as Rebar;
using (Transaction trans = new Transaction(doc, "Add Rebar Bending Detail"))
trans.Start();
// Search for the right Rebar Bending Detail Type
RebarBendingDetailType rebarBendingDetailType = null;
var collectorRebarBendingDetail = new FilteredElementCollector(doc);
var detailTypes = collectorRebarBendingDetail.OfClass(typeof(RebarBendingDetailType)).Cast<RebarBendingDetailType>();
Parameter rebarShapeParameter = rebarStandard.get_Parameter(BuiltInParameter.REBAR_SHAPE);
Element rebarShape = doc.GetElement(rebarShapeParameter.AsElementId());
string shapeCode = rebarShape.Name;
foreach (var type in detailTypes)
if (shapeCode == "00")
if (type.Name == "Bending Detail - Longitudanal Straight Rebars")
rebarBendingDetailType = type;
break;
else
if (type.Name == "Bending Detail - Longitudanal Bended Rebars")
break;
if (rebarBendingDetailType == null)
TaskDialog.Show("Error", "Rebar Bending Detail type not found.");
trans.RollBack();
return;
// Choose the selected number of rebars in the detail
int numberOfRebars = 1;
// Choose the rotation of the detail
double rotation = 0.0; // In radians
// Create Rebar Bending Detail if middle rebars are needed
if (RebarsStandard.Count > 2)
if (i != 0 && i != (RebarsStandard.Count - 1) && i != (RebarsStandard.Count - 2))
rebarRefs.Add(new Reference (rebarStandard));
if (RebarsStandard.Count > 1)
if (i == (RebarsStandard.Count - 2))
// Make a new location for RebarBendingDetail
XYZ newLocationDetail = ((vertex1 + vertex2) * 0.5) + (XYZ.BasisZ * heightParam) + ((vertex1 - vertex2).Normalize() * (55 / 30.48)) + (XYZ.BasisZ * (15 / 30.48));
var bendingDetail = RebarBendingDetail.Create(doc, doc.ActiveView.Id, rebarStandard.Id, numberOfRebars, rebarBendingDetailType, newLocationDetail, rotation);
RebarBendingDetail.AddHosts(bendingDetailElem, rebarRefs);
trans.Commit();
