Add/Remove Host for a Rebar Bending Detail
BertStragier4945
BertStragier4945
Anyone knows if there is solution through the Revit 2024 or 2025 API to simulate Add/Remove Host command for a Rebar Bending Detail?
I have a code to create a new Rebar Bending Detail for all my rebars in a specific host but I want to add identical Rebar sets all in one Bending Detail so I can use the 'Host Count'-parameter in my tag to have the right number instead of adding tags on every individual rebar.
Moustafa_K
I think there is an access to that over here
I also believe on Revit 2025, they add the feature for adding multiple hosts
RebarBendingDetail.AddHosts(Element bendingDetail, IList<Reference> references)
 is that what you are looking for
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
BertStragier4945
Hi @Moustafa_K,
thanks already for your help!
I still have some issues with the references. When I use my Add-in in Revit2025 I receive the following error:
This is a part of my code where I implemented the RebarBendingDetail.AddHosts on line 75:
IList<Reference> rebarRefs = new List<Reference>();
// Place rebar bending detail for all rebars with style Standard
for (int i = 0; i < RebarsStandard.Count; i++)
    Element rebarElem = RebarsStandard[i];
    Rebar rebarStandard = rebarElem as Rebar;
    using (Transaction trans = new Transaction(doc, "Add Rebar Bending Detail"))
        trans.Start();
        // Search for the right Rebar Bending Detail Type
        RebarBendingDetailType rebarBendingDetailType = null;
            var collectorRebarBendingDetail = new FilteredElementCollector(doc);
            var detailTypes = collectorRebarBendingDetail.OfClass(typeof(RebarBendingDetailType)).Cast<RebarBendingDetailType>();
            Parameter rebarShapeParameter = rebarStandard.get_Parameter(BuiltInParameter.REBAR_SHAPE);
            Element rebarShape = doc.GetElement(rebarShapeParameter.AsElementId());
            string shapeCode = rebarShape.Name;
            foreach (var type in detailTypes)
                if (shapeCode == "00")
                    if (type.Name == "Bending Detail - Longitudanal Straight Rebars")
                        rebarBendingDetailType = type;
                        break;
                else
                    if (type.Name == "Bending Detail - Longitudanal Bended Rebars")
                        break;
            if (rebarBendingDetailType == null)
                TaskDialog.Show("Error", "Rebar Bending Detail type not found.");
                trans.RollBack();
                return;
            // Choose the selected number of rebars in the detail
            int numberOfRebars = 1;
            // Choose the rotation of the detail
            double rotation = 0.0; // In radians
            // Create Rebar Bending Detail if middle rebars are needed
            if (RebarsStandard.Count > 2)
                if (i != 0 && i != (RebarsStandard.Count - 1) && i != (RebarsStandard.Count - 2))
                    rebarRefs.Add(new Reference (rebarStandard));
            if (RebarsStandard.Count > 1)
                if (i == (RebarsStandard.Count - 2))
                    // Make a new location for RebarBendingDetail
                    XYZ newLocationDetail = ((vertex1 + vertex2) * 0.5) + (XYZ.BasisZ * heightParam) + ((vertex1 - vertex2).Normalize() * (55 / 30.48)) + (XYZ.BasisZ * (15 / 30.48));
                    var bendingDetail = RebarBendingDetail.Create(doc, doc.ActiveView.Id, rebarStandard.Id, numberOfRebars, rebarBendingDetailType, newLocationDetail, rotation);
                    RebarBendingDetail.AddHosts(bendingDetailElem, rebarRefs);
        trans.Commit();
