New Alignment Method does not work
Message 1 of 12
Hi all,
I´m working with the NewFamilyInstance method, using Lines (to create FamilyInstances) and Face (To rotate and place correctly). That works perfectly. But I have problems in some scenarios, for example, the host that has a slope.
I would need to correct the alignment, getting a new face as a reference, similar to use Align function in Revit.
This is my code, I didn`t have any description of the problem, just the line that causes the exception.
  Reference reference3 = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Face, "Select Face 1");
  Reference reference4 = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Face, "Select Face 2");
            using (Transaction transaction = new Transaction(doc, "Align"))
                transaction.Start();
doc.Create.NewAlignment(doc.ActiveView, reference3, reference4); transaction.Commit(); }
Replies (11)
Message 2 of 12
jeremytammik
What is your question, please?
What exception is thrown?
The elements you wish to create an alignment constraint for must be pre-aligned before you create the alignment, i.e., you have to position them precisely yourself before creating the alignment.
RTFM:
https://www.revitapidocs.com/2020/b3c10008-aba6-9eee-99c9-7e05ace75796.htm
> These references must be already geometrically aligned (this function will not force them to become aligned).
Please be aware of that.
May be that is throwing the exception?
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 12
Hi Jeremy,
I created the elements and they are already geometrically aligned. Also I tried with the combinations described on the documentation. (two planar faces, 2 lines and lines and point). I tried with other elements as Reference, like walls.
The exception just says the alignment cannot be created (an Internal Exception).
Nothing about what the problem could be. References are not nulls, and view is a 3D view. I tried in a PlanView as well.
Other suggestions ?
is There any method that I can use, to align elements to a face?
Message 4 of 12
Revitalizer
may it be that this problem is related to yours?
When "picking faces", this comes to my mind:
https://forums.autodesk.com/t5/revit-api-forum/incorrect-face-normal/m-p/7108787
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 12
I've verified the faceNormal but both are the same.
Thank you for the suggestion.
Message 6 of 12
jeremytammik
Can you achieve what you need manually in the user interface?
If not, you won't be able to do it programmatically either.
The UI mostly gives more precise feedback.
Jeremy Tammik
The Building Coder
Message 7 of 12
matthias.deisboeck
I have two possible ideas:
1.  If you created the elements you shoud regenerate the document before placing the alignment.
2.  Geometrically aligned not only means same FaceNormal also the origin of Face1 must be on Face2.
Perhaps you write a small test programm if you can find this two faces.
In your case you could also project the endpoint of Beam2 to Face1.
Message 8 of 12
Yes, I can. With Align command works perfectly.
Message 9 of 12
jlpgy
Hi:
Try this:
newalignment-to-align-family-instance-reference-plane-with/m-p/5993390
the documentation says:
"These references must be already geometrically aligned (this function will not force them to become aligned)."
FYI:
The following might also be helpful:
https://forums.autodesk.com/t5/revit-api-forum/newalignment-to-constrain-line-to-face-replicate-pick...
单身狗;代码狗;健身狗;jolinpiggy@hotmail.com
Message 10 of 12
architect.bim
Actually I have the same issue. I am trying to align Extrusion face with Reference Plane. Two references are definetly geometrically aligned. But when I try to call NewAlignment method I get the same Exception. Actually I have no idea why this happens. I've tried to regenerate document or adjust the size of the Reference plane. Still not working. =((
Maxim Stepannikov | Architect, BIM Manager, Instructor
Message 11 of 12
architect.bim
False alarm. 😆 Actually I took the wrong face. Now works fine.
Message 12 of 12
architect.bim
In my case regenerating of document really helps as my Extrusion object is created in the same Transaction. Thanks @matthias.deisboeck for the idea!
