.NET SDK 8.0 path not recognised in Revit 2025
jagostinho74
jagostinho74
Trying to get the Revit Macros to work in Revit 2025.
The path to the ".NET dotnet.exe" file appears to be unrecognized, despite its existence.
Anyone else experiencing this? And were you able to fix it?
TIA
Assistant BIM/CAD Manager
Manchester, UK
antonbond
Are you sure you have installed .NET 8.0 SDK and referencing correct version? I had to manually install the .net update to 8.0 & it all worked well on my side
ricaun
You could use the command dotnet --list-sdks to show all the sdk installed in the machine and version.
In my only have the version 8.0.101 sdk.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
nice3point
jagostinho74
Thank you all. A reinstall did the trick.
Manchester, UK
jagostinho74
Thank you @ricaun
This was helpful. For some reasons, it did not get installed the first time.
Manchester, UK
sragan
FYI:  I believe you also have to restart Revit after editing the paths.  (Or maybe it's after installing the SDK.)
