Get Solid from FamilyInstance - keeps returning null
DanielKP2Z9V
DanielKP2Z9V
I'm trying to convert a Beam family instance to a solid for BooleanOperationsUtils.ExecuteBooleanOperation - however this keeps returning null:
Solid depSolid = depElem.get_Geometry(new Options()).OfType<Solid>().FirstOrDefault();
full code:
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace scripts
    [Transaction(TransactionMode.Manual)]
    public class CutGroup : IExternalCommand
      public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            // Get element to cut
            Reference pickedRef = uidoc.Selection.PickObject(ObjectType.Element, "Select an element to cut");
            Element selectedElement = doc.GetElement(pickedRef);
            GeometryElement selectedGeometry = selectedElement.get_Geometry(new Options());
            if (selectedElement == null)
              message = "Please select an element.";
              return Result.Failed;
            // Get group
            Reference pickedGroupRef = uidoc.Selection.PickObject(ObjectType.Element, "Select a model group");
            if (pickedGroupRef == null)
              message = "Please select a model group.";
            Group pickedGroup = doc.GetElement(pickedGroupRef.ElementId) as Group;
            ElementClassFilter filter = new ElementClassFilter(typeof(FamilyInstance));
            IList<ElementId> dependentIds = pickedGroup.GetDependentElements(filter);
            // Use a transaction to group cutting operations
            Transaction tx = new Transaction(doc);
            tx.Start("Cut with Group");
            try
                foreach (GeometryObject selectedGeomObj in selectedGeometry)
                    Solid selectedSolid = selectedGeomObj as Solid;
                    foreach (ElementId id in dependentIds)
                        Element depElem = doc.GetElement(id);
                        if (depSolid != null)
                            Solid cutter = BooleanOperationsUtils.ExecuteBooleanOperation(selectedSolid, depSolid, BooleanOperationsType.Difference);
              tx.Commit();
              message = "Element cut successfully with group members.";
            catch (System.Exception ex)
              tx.RollBack();
              message = $"An error occurred: {ex.Message}";
            return Result.Succeeded;
DanielKP2Z9V
Turned out that I was using wrong function to replicate the "Cut geometry" button. The correct one is SolidSolidCutUtils.AddCutBetweenSolids. Thanks to Aaron.Lu's answer .
Updated code:
namespace scripts
            // Get group
            try
                    SolidSolidCutUtils.AddCutBetweenSolids(doc, selectedElement, depElem);
                tx.Commit();
              tx.RollBack();
