[.Net API] How to create familyInstance of the same parametric family with different parameters one by one?
choshQT24J
choshQT24J
I have a parametric family. For example the parameter is length.
And I want to create several familyInstance with different length.
How should I do in revit api?
Is the only way is to create each type for each new paraters set?
Sorry for my English.
jeremy_tammik
It depends on the family definition and other characteristics of the family, but yes, the process you describe is one typical way to achieve that.
If the parameter of interest is a family type (== symbol) parameter, then you would normally create a separate family symbol for each required parameter value and use that to place the family instances using that value.
Here is some sample code demonstrating how to duplicate an existing wall type and modify its parameters to create a new type:
https://thebuildingcoder.typepad.com/blog/2008/11/creating-a-new-family-symbol.html
A very similar approach works for parametric families as well.
choshQT24J
It works like a charm. Thanks a lot.
