Access Tabs\Project Tabs through API
adikshit
adikshit
Hello!,
Is there currently a way to access these tabs through the API - tabs seem to correspond to the ribbon tabs on the top of the ribbon UI- possibly I am looking for them by the wrong name
Thank you 🙂
jeremy_tammik
Aren't those just the names of the project views that you have opened? If so, you can access them by checking what document and views are opened, and influence them by opening and activating other projects and views.
TripleM-Dev.net
Hi @adikshit,
The UI Tabs themself to change the color etc, yes they can be accessed.
add a reference to "Xceed.Wpf.AvalonDock" (from the Revit install folder)
As a start see this link: Xceed AvalonDock - Revit MainWindow.FindFirstChild returns nul
or do you mean the UIView class for retrieving open views? (also needed to 'link' the Tabs to open document views)
- Michel
adikshit
that was it I was looking for the UItabs - not the names of the project - apologies for the poorly drawn arrow and thanks for pointing me to the right direction
