Hi all,
I'm trying to adjust the layout of the rebar set (width and length).
Q1) I have tried to adjust the width through ArrayLength property (See below code) but nothing happend.
Q2) How Can I adjust the length also?
string prombtMessage = "Pick Rebar Set"; Reference setRef = selection.PickObject(ObjectType.Element, prombtMessage); Element element = doc.GetElement(setRef); Rebar rebar = (Rebar)element; rebar.ArrayLength = rebar.ArrayLength / 2;
P.S: I can do this as a Revit end-user by the sliders of the rebar set.
Thanks in advance.
Hi all,
Thanks in advance.
I have modified the length through the below parameter
rebar.get_Parameter(BuiltInParameter.REBAR_ELEM_LENGTH).Set(maxRebarLength);
but I still can't set property ArrayLength !
You have to set the layout Rule, the array length is included there.
Rebar.SetLayoutAsMaximumSpacing(...), Rebar.SetLayoutAsFixedNumber(...), etc.
