Material reference
Material reference
Material reference
Hi reviteers,
There are 7 types ofExternalFileReferenceTypes.
I am using this code to retrieve references in a revit project:
ICollection<ElementId> externalReferences = transData.GetAllExternalFileReferenceIds();
I can retrieve:
ExternalFileReferenceType.AssemblyCodeTable
ExternalFileReferenceType.CADLink
ExternalFileReferenceType.RevitLink
ExternalFileReferenceType.KeynoteTable
but there is also a
ExternalFileReferenceType.Material
But the code above never gets materials ??
What is this setting for ? Is it supposed to retrieve the rendermaterials ? And if so, why doesn't the code above retrieve them ??
Is the a way to get a list of missing materials and fix the links ?
JimJia
The materials are not included as ExternalFileReferences after Revit2012. So you cannot get anything by ExternalFileReferenceType.Material.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
okay, but is there any other way to get to the material locations ?
I made a tool to fix missing links and it works perfect for keynotes, assembly codes ect. but not for custom loaded materials.
JimJia
As far as I know, there is no API support for getting customized material location.
But if you want to get the installed material location, you can use the registry key "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\ADSKAssetLibrary\2017" and the Key Name "LibraryPaths" to retrieval the installed material library location.
Hope that can help you.
Jim Jia
