Merge or combine filled regions
ameer.mansourWAK8Y
ameer.mansourWAK8Y
hi
any thoughts on merging or combining filled regions to be a single region? using Revit API
RPTHOMAS108
Yes this is actually quite an easy task despite outward appearance.
The filled region geometry contains a flat solid (solid with single planar face).
Therefore you can extract the solids
use BooleanOperationsUtils.ExecuteBooleanOperation with Union
You would have to union each result of the operation in turn with the next solid to union
Then extract the Edges as CurveLoops from the face of the new solid and create a filled region with it.
RPTHOMAS108
If you can't get it to work that way due to the BooleanOperationsUtils not liking flat solids then.
You can extract the current face edges as CurveLoops then extrude them with:
GeometryCreationUtilities.CreateExtrusionGeometry(IList(Of CurveLoop), XYZ, 1)
To create solids with a thickness.
Carry out union operation on those to create new solid. Finally on the new solid extract the edge CurveLoops from the face with face normal opposite to the extrusion direction (original plane extruded away from).
ameer.mansourWAK8Y
that is a good idea instead of doing the hassle of merging algorithms.
it works in most cases but in some, I get this exception and I don't know what is it and what to do!
MiguelVJC82W
Did you ever figure this out?
