Material volume in a schedule
CRJFusco
CRJFusco
I have been trying for a bit to work this out but need help if there is any. I work for a precast company and have an architectural layer and structural layer. The family I have is made with two layers of precast material but want to have both volumes given into a schedule that also provides other parameters like weight, size and a few other bit of information. Is is possible to have this outside of a material takeoff?
jeremy_tammik
It sounds to me as if you are asking this from an end user point of view and not programming Revit using the Revit API yourself. In that case, this is probably not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. Non-programming issues are better raised in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not.../5607765
The people there are probably better equipped to address this topic than us programming nerds.  I hope this clarifies.  Thank you for your cooperation and understanding.
Best regards,
Jeremy
