Get if room is in area boundary
SamBerk
SamBerk
Hi
How can I get with the C# Revit API if a room element is inside an area's boundaries?
By inside I mean if the room is completely inside or the edges are exactly at the same place.
Like:
bool isInArea = area.IsRoomInside(room);
jeremy_tammik
I would look at this as a 2D Boolean operation task. Several solutions to this are discussed by The Building Coder:
SamBerk
Hi @jeremy_tammik
I've solved it using your utils I've downloaded a while ago.
I can't find the exact URL now, if you can share it here I can mark it as the solution.
Thank you
