Looking for a Guide for Revit Libraries in Pythonshell
babysatch
babysatch
I have noticed often, that people add a reference in their python code in Dynamo to RevitServices by the following code in order to use DocumentManager and TransactionManager:
'# Import DocumentManager and TransactionManager
clr.AddReference(“RevitServices”)
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
Does anybody have an idea where I can find all methods, properties and members of the Revit librares "RevitServices" and "RevitNodes". I cannot find them in RevitAPI.chm.
Thank you.
jeremytammik
I would suggest you discuss this with the creators of RevitPythonShell, either in its GitHub source repository, or on StackOverflow, as explained there:
https://github.com/architecture-building-systems/revitpythonshell
https://github.com/architecture-building-systems/revitpythonshell#support
Happy New Year to you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
office
babysatch,
the problem you are addressing is not a problem of a lack of documentation of the revit api nor is it an issue resulting of the use of the revit python shell as jeremy suggests.
the dynamo addin (application) implements a own document manager and a own task manager. why this is done? consult the dynamo branch on github.
if you now have a python code that accesses a document (what you most certainly will do) or make changes to the revit database you have different options depending if you are in a dynamo environment or not..
i.e python shell.:
import clr
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
#.......any code to get an elementid
wall = doc.GetElement(element.id) t= Transaction(doc,"set wall parameter") t.Start() wall.LookupParameter("Any shared Parameter").Set(value) t.Commit()
dynamo python code:
from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument #...... wall = doc.GetElement(element.Id) TransactionManager.Instance.EnsureInTransaction(doc) wall.LookupParameter("Any shared Parameter).Set(value) TransactionManager.Instance.TransactionTaskDone() OUT = wall
best peter
