Uncut beam and column by api?
I am new in Revit develop.
I want to uncut the beam and column as shown in the picture.
I can do it manually, by "modify > geometry > uncut".
I want to do it by api.
I try to use SolidSolidCutUtils.RemoveCutBetweenSolids(doc, e1, e2); where e1 is the beam and e2 is the column but nothing happened.
Does anyone know the correct way to do it?
My code is something like this:
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class Unjoin : IExternalCommand {
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) {
        UIApplication uiApp = commandData.Application;
        Document doc = uiApp.ActiveUIDocument.Document;
        Transaction trans = new Transaction(doc);
        trans.Start("Unjoin");
        unjoin(doc, BuiltInCategory.OST_Columns);
        unjoin(doc, BuiltInCategory.OST_Walls);
        unjoin(doc, BuiltInCategory.OST_StructuralFraming);
        trans.Commit();
        return Result.Succeeded;
    void unjoin(Document doc, BuiltInCategory cat) {
        foreach (Element e1 in new FilteredElementCollector(doc).OfCategory(cat)) {
            foreach (ElementId id in SolidSolidCutUtils.GetCuttingSolids(e1)) {
                Element e2 = doc.GetElement(id);
            foreach (ElementId id in SolidSolidCutUtils.GetSolidsBeingCut(e1)) {
                SolidSolidCutUtils.RemoveCutBetweenSolids(doc, e2, e1);
            foreach (ElementId id in JoinGeometryUtils.GetJoinedElements(doc, e1)) {
                JoinGeometryUtils.UnjoinGeometry(doc, e1, e2);
jeremytammik
Have you tried using the GeometryInstance class GetSymbolGeometry method?
http://www.revitapidocs.com/2017/7daa0e66-9921-3214-91f4-028e8cfd2618.htm
"Computes the geometric representation of the symbol which generates this instance."
Merry Xmas!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you for your reply.
Could you please provide more information about that?
I want to export the revit model into ifc file without cut between columns and beams. Can I achieve this by using GetSymbolGeometry?
