Loft with guidecurves
Hi!
I have been trying to do a loft between two profiles. However, the Loft that i get it's not the way I want it too, so I want to define guidecurves, like it s possible to do in Dynamo and in AutoCad.
Is thia possible via API? Please help.
Thanks in advance.
jeremytammik
Dear Aafm92,
If you can achieve that in Revit via Dynamo, then it is definitely possible via the Revit API as well, because that is the one and only way that Dynamo interacts with Revit.
So, please answer your own question yourself by examining the Dynamo node source code and share the answer with us here.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Revitalizer
Hi Jeremy,
happy new year for you, too.
I disagree with your first sentence because there are geometric operations which can be performed in Dynamo but not in Revit.
Dynamo has its own 3D modeler, so it has more intersection modi than Revit.
http://forums.autodesk.com/t5/revit-api/geometry-intersect/td-p/5963258
Cheers,
Rudi
Rudolf Honke
Software Developer
Mensch und Maschine
