Geometry intersect
Geometry intersect
Geometry intersect
Can i have implemented this Dynamo script in Revit API?
Revitalizer
first thought: no, you cannot.
There are supported intersections between Solids and Curves, Faces and Curves, Curves and Curves, Faces and Faces.
But no Solid-Face intersection.
Second thought: hey, you could workaround it.
Get the boundary curves of your face, do Solid-Curve intersections, collect the resulting curves.
Or get the faces of your solid, do Face-Face intersections, collect the resulting curves.
But how to get the area of these curves, as they could consist of several rings or describe a spherical surface...
Third idea: if Dynamo is open source, you could read the code, find the relating geometric function and try to call it from your own addin.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
jeremytammik
Dynamo IS open source, totally!
Jeremy Tammik
Developer Technical Services
The Building Coder
htlcnn
Not all of Dynamo parts are opensource. ProtoGeometry is one of them.
BIM_S_S
I have 2 geometry elements and i can't get intersection geometry please help
You can use the "DoesIntersect" from Dynamo's ProtoGeometry.dll.
Autodesk.DesignScript.Geometry.Geometry.DoesIntersect(Autodesk.DesignScript.Geometry.Geometry)
htlcnn
It does not work when you reference ProtoGeometry.dll outside Dynamo environment.
