Load list of 3d Views from Revit
How I can load list of 3d views from Revit instead my hand written data
new CameraViewModel ("View1"){ Width = 100, Height = 100 } and etc.
This is my code with hand written data
public class CamerasCollectionModel
        public ObservableCollection<CameraViewModel> Cameras
            get
                return cameras;
            private set
                cameras = value;
        public void Load() => Cameras = new ObservableCollection<CameraViewModel>
            new CameraViewModel ("View1"){ Width = 100, Height = 100 },
            new CameraViewModel ("View2"){  Width = 200, Height = 200 },
            new CameraViewModel ("View3"){ Width = 300, Height = 300 }
        private ObservableCollection<CameraViewModel> cameras;
jeremytammik
The standard approach to retrieve all Revit database elements is by using a filtered element collector:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
For instance, to get all views, you can use:
FilteredElementCollector views
  = new FilteredElementCollector( doc )
    .OfClass( typeof( View ) );
You may just want View3D elements, and you may want to add many other filtering criteria to limit the selection.
You can find many similar questions and answers here in similar previous threads.
Jeremy Tammik
Developer Technical Services
The Building Coder
